HOW TO CHANGE JAPAN RADIOS TO NZ FREQUENCIES - WITHOUT A BAND EXPANDER
Factory fitted BMW radios from around 2000 onwards have a 'world tuner' inside them. The same radio can be used anywhere in the world.
The radio can be programmed to operate in JAPAN mode (FM = 70-90), or in OCEANIA or EUROPE mode (FM=87.5-108). They also do a USA and CANADA mode but that's not useful here in NZ.
BMWs imported from Japan have their radios set to JAPAN mode (wonder why?)
These can be readily re-programmed to NZ frequencies as follows:
1. Switch on radio 2. Within 10 seconds, press and hold down the 'm' button until the serial number appears (takes around 10secs) to enter the radio's service menu. 3. Use the + or - buttons to cycle through the menu settings until you see AREA JAPAN or just JAPAN (varies a bit depending on radio) 4. Use the 1...6 buttons to select either OCEANIA (or OCE) or EUROPE - both are valid settings for New Zealand - see below for differences. 5. Switch radio off to store the change
Voila! Your radio has now bee reprogrammed to receive NZ FM frequencies! Also, the cool RDS features will now be available.
Differences between OCEANIA and EUROPE modes on an E46 Business RDS radio (other radios may vary slightly):
a) EUROPE has LW, MW and FM. OCEANIA has AM and FM only.
OCEANIA shows ST for a FM stereo station; EUROPE doesn't show anything for stereo or mono FM stations.
c) EUROPE has the softkeys set to RDS and TP; OCEANIA has RDS and PTY
Which ever one you choose - OCEANIA or EUROPE - is up to you, they both work.
I hope you find this info useful, and that the forum moderator makes this a 'sticky'
PS: If anyone wants any info or help with BMW radios - talk to me. I've helped around 80 BMW owners convert from Japan radios to proper NZ radios for their BMWs, thus keeping the vehicle in original condition, and obtaining proper radio reception. Send me an email for more info!
Cheers, Jochen
Hey,
I have a 850i from Japan would you walk me through the process of resetting FM to CANADA
Jochen, Looking to see if you've found a way to reprogram a 2008 335 with I-drive and navigation. I have the same problem with my US spec BMW in Germany. I can't receive the german frequencies nor the RTTI traffic info. If there was a "M" button, it would be all to simple, unfortunately, there isn't. Any suggestions?
Thanks for your help.
Eric
QUOTE (jochen @ Apr 8 2006, 03:30 PM)
Here's a useful 'How to' for BMW fans:
Car: '97 E36 328 TI M52B28
Car 2: Nissan Xtrail
Car 3: Suzuki Swift Ltd
QUOTE (Erock @ Jul 24 2009, 07:54 AM)
Eric
Being a 2008 car, the dealer should be able to do that for you
Car: BMW 745i e65
Car 2: Benz S500 w220
Car 3: Toyota Camry
Race Car: Honda Accord
Jochen,
You are really god sent.. Been looking for a site which would help me address my radio problem with my BMW 745i e65. The car was produced 2003 and comes with iDrive. Problem is the radio frequency is in japan mode. I do not wish to replace the HU so anything i can do? Im in the Philippines. Please help. Thank you.
Car: Now: 2007 Turbocharged German PKW Used to have: 97 E39 540i Montreal Blue, fully optioned (since sold)
QUOTE (tebs69 @ Oct 24 2009, 02:37 PM)
Jochen,
You have to find a good intelligent BMW engineer/tech that can reprogram the car to Europe mode (not Japan)
Or: swap out the antenna amplifier - left rear c pillar - with one from a native Singapore / Philippines car. The radio tuning is done in the antenna amplifier, as long as you never reprogram the car, the Singapore antenna amp will stay set for singapore and radio reception will be OK
Watch out for different software versions! You won't be able to tell without any tools though...
mmm... BMW 540i.... burble burble guzzle guzzle ROARRRRR....
Car: BMW 745i e65
Car 3: Toyota Camry
Hi jochen,
Thank you for taking time to reply. Did you mean to say that by simply changing the antenna amplifier into singapore/philippine frequency will be ok? Is there no need to do anything with the HU like reprogram it or anything like that? Thank you.
Note the same part numbers in use for the different markets, the antenna tuner varies only in how it is programmed.
Therefore, look at the part number of the tunr in your car to be 100% certain you get the same type. Then, get it from a car from the same market as what you want eg: Singapore, UK, Europe, Philippines, Malaysia etc
The other way to do this, which could be cheaper is: 1. Remove the antenna tuner from your car and fit to a Singapore, UK, Europe, Philippines, Malaysia etc market vehicle (but NOT US or Japan market) 2. Recode the car using BMW software to make the antenna tuner coded correctly for the car. 3. Refit the tuner back to your car.
hey mate is there have any chance for E39 1999 528i with nav TV??(Jap model) i just can't find any button call "M" even the new 16:4 tv doesnt hav M bottom either !!
whts the M buttom mean?? Mode?? Memory?? Mxxxx?? i have no idea......plz help
My tv look like this:
The new 16:4 Tv
NOT M BUTTOM ON BOTH .......what??
cheers
UPDATE: i pressed Traffic buttom about 10 second n the serial number appears BUT i still can't find area Japan or Japan lol
This post has been edited by BrianE39: Nov 24 2009, 02:34 PM
QUOTE (BrianE39 @ Nov 24 2009, 03:49 PM)
No. The ability to reprogram the radio started in vehicles made in September 2009 and newer
Your 1999 E39 has the old-generation non-reprogrammable radio in it.
To make the radio work in NZ, simply exchange the Japanese radio module with the European equivalent radio module. This is easy and relatively cheap to do, on ebay Germany the radio modules sometimes sell for as little as <$100 NZD
PS: M means "Memory" PPS: Service mode on the 4:3 monitor and 16:9 monitor is activated with the SELECT button PPPS: Jap radios of the age of your car do not have a Service Mode
Hey Jochen,
Am wondering if you can help. I have got a 2002 BMW 530i from Japan with the TV navigation unit (same look as the photo provided in the previous post- screen in the midle and buttons on both sides and cassette behind the electronic opening face) I have tried to reprogram the unit so it can recieve NZ radio station and have tried switching the radio off and holding the "select" button. it comes up "pres ON" and then if i try again it comes up with "pres off" have tried fiddlingwith other buttons while this message is on but nothing happens and goes back to the radio station display. Does this mean this stereo cant be reprogrammed? any help would be appreciated
Car: 1978 520i 1999 525i
Race Car: E30 Series 320i
Car No. #63
QUOTE (Sharad @ Dec 8 2009, 08:22 PM)
Hey Jochen,
Hi,
PM me with the last 7 digit chassis code & I will confirm build date - this determines what tuner is fitted. If world tuner - I can then give you the sequence for programming your radio
