QUOTE(beemn @ Jan 9 2007, 06:27 PM) [snapback]105657[/snapback]
will it work on an e90?
Extracted from the WDS:
Brief description of radio
For the E90, there are four radio levels as optional extras.
Radio Audio without drive
Radio Business CD with CD drive
Radio Professional with CD-ROM drive
Radio Professional with MD drive
In addition, the navigation system Business (M-ASK) and navigation system Professional (CCC) can also be chosen. Different audio system can be combined with the radios. As standard, the stereo system is fitted with all radios (no external amplifier).
Audio programThe audio systems in the BMW 1 Series are divided into 3 levels:
Stereo system
HiFi system
Top Hi-Fi system
The audio systems differ in that various sound pressures can be achieved or there is improved system linearity. The stereo system consists of 6 loudspeakers; the HiFi system or top-hifi system consists of 10 loudspeakers and various additional amplifiers. The central bass speakers are located under the front seats.
AerialsRear-window aerials and a roof-mounted aerial are used in the E87. The rear-window aerials deliver the signals for the reception of FM. The roof-mounted aerial receives the signals for the telephone, FM and AM. Antenna diversity is fitted on the Radio Business CD and Radio Professional or higher. Antenna diversity contains the aerial amplifiers. Antenna diversity switches the aerials for FM.
Service modeProceed as follows to call up the Service mode:
Terminal 30g ON
Switch off the radio
Switch on the radio again
Within 8s for a duration of 8s, press the button for manual station-search function
The radio switches into the Service mode
So put the radio into service mode and see if you have an AREA option available to you. If so, set it to EUROPE.
mmm... BMW 540i.... burble burble guzzle guzzle ROARRRRR....
